LAN-2-LAN tunnel ACL
gdapriva9
How can I assign an ACL to an existing LAN-2-LAN tunnel. I want to limit traffic through the tunnel down to a specific IP address and TCP port?
6 Replies 6
Jon Marshall
Which device and what version of software are you running on that device ?
Jon
ASAs on both ends with IOS ver 7.2
Easiest thing to do would be to use a vpn-filter on the L2L tunnel. Please see attached link for details
http://cisco.com/en/US/docs/security/asa/asa72/command/reference/uz_72.html#wp1411607
Jon
purohit_810
Level 5
Level 5
You can use Policy NAT and access-list.
Dharmesh
purohit_810
Level 5
Level 5
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
See on above link, it has some hint for Burst size.
Dharmesh
gdapriva9
Resolved the issue myself ... Thanks everyone
