Does the 76xx routers supports EoMPLS without SIP installed?
Mar 24th, 2008
Dear Sir!
Can you tell to me, does the 7600 series of routers supports EoMPLS without shared port adapters (SPAs) and SPA interface processors (SIPs)?
I.e. if we have 7606S-RSP720C-R, WS-X6704-10GE ports connected to backbone and
WS-X6408A-GBIC with WS-X6148A-GE-TX ports connected to our DataCenter
(without any SIPs and SPAs installed on board).
Can we make EoMPLS for such clients, which are should connected
to our DataCenter through remote CAT3750-METRO?
Best regards,
Maxim
Overall Rating: 5 (2 ratings)
pbenin Tue, 03/25/2008 - 06:12
we use C7600 with WS-X6748-SFP and WS-X6148A-GE-TX but without SIP/SPA.
The system supports EoMPLS in VLAN-mode (xconnect on subinterface).
There are generally two modes of EoMPLS:
(1) PFC Based MPLS and related applications
mode
(2) WAN Based MPLS (SIP/SPA/OSM/ES20) and related applications mode
(1) Is only dependent on which Sup do you have
and generally works with most of the Ethernet (LAN) ports... If you have PFC-3B or later along with Sup-720, Sup-32 (which is PFC-3B) you can do it.
(1) Has some disadvantages - for example you cannot having L2 switching AND MPLS EoMPLS...
I.e. if you want to do local switching on Vlan 200 and part of the traffic to be switched part of the traffic to be EoMPLS you cannot do it without SIP/SPA/OSM/ES20
(2) In this case you need to check very well what you're looking for. These are expensive and they support MPLS and its Applications and even support VPLS, which is not possible with (1)....
I hope this answer your quesiton...
ric_asomgdata Tue, 03/25/2008 - 19:53
Please share some reference material on (2)WAN Based MPLS (SIP/SPA/OSM/ES20) and related applications mode.
