Applying FAC-CMC for multi Tenant Environment
Mar 25th, 2008
Hi all,
Design constraint!!!!
Lets say A CCM Cluster has separate partitions for each client,& FAC/CMC doesnt belong to any partition by design, so If FAC/CMC applied on any route pattern then it will be applied to whole cluster for outgoign calls.
Only work around is to create complete dial plan(route pattern) for each customer, but that route pattern will be assigned to that customer's partition only.. This will make the configuration tedious but functional
As configuring CMC/FAC @ Route Pattern(RP) level will not be practical in multi tenant design, so there is need in CCM design to provide CMC/FAC on either DN OR As a Service subscribe to device profile.
Above is the practical scenario m facing @ work.
Appreciate the community for elaboration.
Jaime Valencia Mon, 03/31/2008 - 11:17
if you feel that the product should have that capability get in touch with your AM and see the possibility of opening a PER for that
javalenc.
Jaime Valencia Mon, 03/31/2008 - 17:32
PER = Product Enhancement Request
talk to your AM in order to see if you can present one. Be aware that just the fact of presenting it does not mean it will be implemented in a future release
javalenc
