CME TO CM LICENSE UPGRADE FOR UNITY
Mar 25th, 2008
  • Bronze, 100 points or more
hi all,
i hv CUE 2.2.2 (AIM-router2611),which shows license for CME. i want to integrate CUE to CM 4.1, is it possible to upgrade CUE license from CME to CM? if yes then How?
Thanks in Advance,
Overall Rating: 5 (1 ratings)
hardiklodhia Tue, 03/25/2008 - 07:04
Hi Brandon,
can i convert the existing CME license into CCM? or i hv to download CCM license? if yes, then how can i retain my existing license?
pls guide.
Brandon Buffin Tue, 03/25/2008 - 07:08
  • Purple, 4500 points or more
You will have to download the CCM license. You could also download the CME license if you want to keep a copy. No need to retain it from the current system.
Hope this helps.
Brandon
