AON Management Console 2.4 Install
Mar 25th, 2008
i'm trying to install AMC with manual:create java keystore, CRS-file and submit CRS in CA, and then import certificate in my's ok.but when i begin to install AMC, it says "The KeyStore you provided does not have any KeyPairs Failed to configure keystore information".
anybody use this module and soft? please help!
aghaznavi Mon, 03/31/2008 - 07:06
The process to use a self-signed cert would involve first installing amc with a valid cert (you cannot install amc without a valid cert, you can however after installing it with a valid cert modify it to work with a self-signed cert), and then the install keypair.
