ip subnet-zero and the use of the broadcast subnet and subnet 0
Mar 25th, 2008
Hi there, just a quick question really - if for instance the ip subnet-zero command has been applied to a router can the subnet 0 or broadcast subnet be used with an internetwork? i.e lets say on a point-to-point serial link or a LAN segment?
Garry
Jon Marshall Tue, 03/25/2008 - 05:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Garry
Yes you can use both the subnet 0 and all ones subnet with "ip subnet-zero". Note that after IOS 12.0 the default is ip subnet-zero.
See attached link for more details.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093f18.shtml
Jon
grichardson661 Tue, 03/25/2008 - 05:53
This is what i was looking for! The reason i ask is because of some questions on the Boson CCENT exam which try and catch you out on subnetting questions.
