Router 2650 Boot Looping
Mar 25th, 2008
Help Please. I have a router 2650, when I turn on, it is showing (see below)
loadprog: bad file 0x0
load: cannot load "flash"
How do I break into this router? I am using windows XP with hyper termianl with default setting 9600. Thanks,
Overall Rating: 5 (1 ratings)
graemeporter Tue, 03/25/2008 - 06:33
You need to connect your console cable to the router and open your Hyperterminal session.
When you switch the router on, hit "CTRL-BREAK" several times; keep doing it until it shows you the "rommon 1>" prompt.
From there, you should be able to reconfigure the router to use the correct IOS image, or install a new IOS image if the old one is corrupt.
Hope this helps!
hoadotnguyen Tue, 03/25/2008 - 08:09
It is still show the same error:
loadprog: bad file magic number: 0x0
boot: cannot load "flash"
Here is what I did.
I disconnect HT
Reconnect HT
Hold down CTRL key
Turn router power on
Press Break key
Other solution please. Thanks,
hoadotnguyen Tue, 03/25/2008 - 13:47
I have gone to this site, but rightnow. My router is still boot with infinity loop. I can not get to this rommon 1>. I wish I would but still do looping over and over. Help please.
