How to determine the script and prompt locations for the IP IVR
Mar 25th, 2008
Hi;
How to determine the location (path) of the scripts and the prompts at the IP IVR?
Bilal
rbua Tue, 03/25/2008 - 07:33
Hi Bilal,
in order for us to assist you, would you please clarify what you are trying to do and on which IPIVR release?
I acknowledge it has to do with Scripts and Prompt handling but it is unclear how/what/why you are looking for with regards to it.
Thanks for posting a bit longer questions next time providing the needed level of details.
Riccardo
bilalghayad Wed, 03/26/2008 - 02:06
Hi Riccardo;
Thanks alot :) -
I am using IPCC Enterprise version 5 with IPIVR 3.1(3), we need to format it and we do not need to loose the script and the prompt, so I would like to take it out, that is why I asked in which path it is existed to take it out.
Bilal
rbua Wed, 03/26/2008 - 02:09
For 3.1.3 you should be good with a BARS backup, a local copy should be also in the wfaffid folder, do a find for .aef.
Riccardo
