configuration issue
Mar 25th, 2008
We currently have ntp sevrers defined in network as ip address, we need to change ntp server ip address and I though I would configure them in router and switches as their DNS name and then change the ip address in the server. When I go do that it shows still ntp with its ip address instead of a name and in Cisco 3560 it doesn't like ntp server <name>.
Any idea what could be wrong. I have dns server and ip domain-name is already defined.
guruprasadr Tue, 03/25/2008 - 06:31
HI Nawas, [Pls Rate if HELPS]
If i am not wrong in understanding your question,
You required to Configure the new NTP Server and also would like to configure a DNS Server to for resolution.
>> Configure the NTP Server & initiate some interesting traffic for the Server (using PING)
>> Execute show NTP associations
>> ip domain-name
>> Check from your LAN Segment in some PC's whether the NSLOOKUP occurs for the domain-name.
>> So the ip domain-name should work
Pls clarify more on your question. Pls Rate if HELPS.
Best Regards,
Guru Prasad R
nawas Tue, 03/25/2008 - 06:38
No, this is not what I meant. I already have ntp and dns sever definied in my touers and switches. I need to replace ntp sevrer ip address configuration with its name for example I have
ntp server and I need to replace this with and Cisco 3560 doesn't like this command. I have Cisco 6509 with CatOS, they take the command but when i do show config it show ntp server instead of ntp
