1242AG Access Point with ANTM5560P Antenna?
scottmac Tue, 03/25/2008 - 07:30
  • Green, 3000 points or more
I believe the intention is that it can be used for 2.4G or 5.6 (802.11a/b/g) ... i.e., the antenna is resonant for either band (versus optimized for one band or the other).
The docs (http://www.cisco.com/en/US/docs/routers/access/wireless/hardware/notes/antwall.html )mention that it can also be used in tandem for diversity.
If you want to use this model of antenna for each of two bands installed on your AP, then you would need at least one antenna for each radio (minimum two antennas, maximum four).
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
