[Cisco 1841] Being desperate with wireless config
Mar 25th, 2008
hi guys,
I'm desperate in need of some help configuring my 1841 as a basic
access point.
First let me explain what I need it for. I need to connect my laptop,
using a wireless connection, to a device connected to one of the FE
ports.
I see the SSID in my Windows connection manager, but I can't connect
to the router. Als I think I need to set-up a route from the WIC to
one of the F! ports.
Is someone capable in sending me a basic, working config file?
Below My config file
Current configuration : 3889 bytes
! Last configuration change at 13:32:05 UTC Tue Mar 25 2008 by hwsound
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
no aaa new-model
resource policy
ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-2334219808
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2334219808
revocation-check none
rsakeypair TP-self-signed-2334219808
crypto pki certificate chain TP-self-signed-2334219808
certificate self-signed 01
// cut to make the message shorter //
quit
username xxx privilege 15 secret xxx
bridge irb
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ETH-LAN$
ip address 192.168.1.120 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface Dot11Radio0/0/0
no ip address
ssid HerrieWeb
vlan 1
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0
station-role root
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CCCCCCC
Cisco Router and Security Device Manager (SDM) is installed on this
device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a
privilege level of 15.
Please change these publicly known initial credentials using SDM or
the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you
want to use.
For more information about SDM please follow the instructions in the
QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
sweigle Mon, 04/14/2008 - 08:00
As Andrew said,
Add the bridge-group command to your Fast Ethernet interface. This should delete your IP address on the FE. Now your FE will be bridged to your wireless network. All IP addresses then, will be on the same subnet as your BVI interface. You will either need to assign IP addresses on the 192.168.10.0/24 statically for your hosts or you need a dhcp server on the 192.168.10.0/24 for your hosts.
