gsm gateway
paolo bevilacqua Tue, 03/25/2008 - 07:33
  • Hall of Fame,
    Founding Member
A bit depends on the gsm gatway too, not all are the same. However a good gsm gw brand will give you same the quality as a good gsm handset.
