HTTP 500 - Error in a Call Manager Publisher Server
Mar 25th, 2008
Hi everybody
I have a CCM cluster 4.2(3) - the cluster was working fine but since some days ago when I try to open the administration page https://<ipaddress>/ccmadmin, I get a HTTP 500 - Internal server error and the page is not displayed. The IIS, the World Wide Web Publishing Service, and the other Cisco Call Manager Services are running. Other Cisco CCM pages like the DNA or the BARS pages are working fine. I restarted the server but it didn't work.
What can I do to restore the administration of the cluster?
Yhank you all
Nicolay
Overall Rating: 5 (2 ratings)
Jaime Valencia Tue, 03/25/2008 - 17:46
  • Cisco Employee,
  • Hall of Fame,
    2011
that usually are bad news, in some cases a simple iisreset clears it but if other pages are available the issue might be that the web pages for the ccmadmin site got corrupted, open the iismanager on the server and verify the pages are in there.
my experience with those cases is that usually it ended up in a rebuilt or an upgrade so the files were installed again.
i'd really recommend to raise a TAC so they can verify the iisadmin status and maybe look at some iis logs to determine if there is anything else you could try
javalenc
if this helps, please rate
gogasca Wed, 03/26/2008 - 01:48
  • Green, 3000 points or more
Hi Nicolay,
For CCM Admin use IIS Console from Administrative Tools (Internet Services Manager) and change for CCMAdmin folder properties Change application protection from High to Low and let me know
Jason Aarons Tue, 05/27/2008 - 07:09
  • Bronze, 100 points or more
This is also a known issue if you have a bad password or username with 4.2. You shouldn't get a http 500 with a bad password!
robray_sc Thu, 04/30/2009 - 12:04
did you have a fix for this? I'm running into the same issue.
