Route Pattern for third-party SIP Devices
Mar 25th, 2008
we have connected our Nokia E-Series Phones to our CUCM 6.1 via Sip. Everything
is fine so far. The issue is that the phonenumers in the mobilephone
addressbooks are in an international form e.g. +4901709197... or
+440207..., and I don't know how a route pattern needs to be look like to
match such numbers. In the moment I got the error message "address is
not in use" on the nokia phone, when I try to dial such a number and couldn't see anything in the isdn debug.
We have added one E61 via SCCP to the CUCM 6.1. The problem is nearly the same, but with this phone I got an ISDN debug output, which looks like as the callmanager or gateway just ignores the "+" and dropps it.
The only existing outgoing route pattern we have in the moment is 0.X with activated
overlap sending.
Any ideas to make it possible to dial these "+ numbers"??
gogasca Wed, 03/26/2008 - 01:53
the problem with Intl numbers is the lenght
try Application Dial Rules to see if can help you for some countries...we raised a defect against that and we are working in this
+ since plenty of customers are requesting this feature.
pasimahone Wed, 03/26/2008 - 03:49
Is there any specific reason why you want to use SIP?
You could also try Nokia Intellisync Call Connect for Cisco client which enables SCCP to Nokia E-series phones.
Nokia SCCP client converts + sign to 00 by default. So when you make a call e.g. to +49017091197.. the client actually calls to 0049017091197
You can find latest client and documentation from here:
