Resync multiple subscriber MWIs
Mar 25th, 2008
We have a Unity 4.2.1 dual integration system (CM and PIMG). We are in the process of migrating sites to CM. During the cut we need to change the integration for the subscriber from PIMG to CM and refresh the MWI. When we cut large sites it is a pain to do this manually through saweb for each subscriber. The sp_UpdateSwitchForSubscriber stored procedure allows me to change the switch type in a batch process but I haven't found a similar solution for refreshing MWIs.
I'm wondering if anyone has any suggestions
thanks
Jaime Valencia Tue, 03/25/2008 - 14:40
  • Cisco Employee,
  • Hall of Fame,
    2011
in the UTIM under each integration is the Resync MWI option to do this job
javalenc
if this helps, please rate
kseraphine Tue, 03/25/2008 - 17:47
Right, I should have stated in my initial post that I'm trying to avoid resynching 2000+ MWIs during the working hours.
I'm looking to be more granular than that.
