Cisco Tools
Mar 25th, 2008
Are there any tools out there that are available so that computer requesting a service to get dropped automatically? For example, we have a computer that hits a webserver but for some reason when it hits the server the clogs the web server down. We are looking for a tool where we can control what its the server and what does not. If a computer does hits the server we would like to communication to be dropped before it hits the server.
thiru.vel10 Tue, 03/25/2008 - 19:21
Solar Wins tools is there for this kind of monitoring this is tools is helpful for you.
Istvan_Rabai Tue, 03/25/2008 - 21:04
  • Gold, 750 points or more
Hi Ramos,
The first solution that comes to my mind in this case is to use an access-list.
You should apply an access-list on the incoming interface of default gateway of the computer to restrict its access to the ip address of that web server.
It may look like the following example:
Computer's ip address is 10.1.1.1 255.255.255.0, it is connected to fa0/1 interface of the router through a switch.
Web server's ip address is 192.168.1.1 255.255.255.0.
Configuration on the default gateway router:
conf t
access-list 101 deny ip host 10.1.1.1 host 192.168.1.1
access-list 101 permit ip any any
interface fa0/1
ip access-group 101 in
This access-list will deny the computer's access to the web server only, but it will allow any other traffic. The computer will be able to access anything else.
Cheers:
Istvan
