Acess-list with an object-group
Answered Question
Mar 25th, 2008
I have a pix515e ver 6.3
I defined a object-group
eg. pix1(config)#obect-group network mxly
network-object 200.65.23.0 0.0.0.0
network-object """"" " "
network-object 202.65.30.0 0.0.0.0
pix(config)#access-list outside_acl permit tcp mxly 67.90.0.34 eq 25
the error is invalid ip address mxly.
How can I use or what is the correct context to use the object-group in my access-list as the source.
Correct Answer by Jon Marshall about 8 years 11 months ago
In addition to previous post you need to modify your acl ie.
should be
access-list outside_acl permit tcp object-group mxly host 67.90.0.34 eq 25
Jon
Overall Rating: 5 (1 ratings)
derrickc Tue, 03/25/2008 - 19:03
For the network-object command, use a network mask. For example:
network-object 200.65.23.0 255.255.255.0
It looks as if you are trying to use a wildcard mask.
Other than that, it looks fine.
Correct Answer
Jon Marshall Wed, 03/26/2008 - 00:29
should be
Jon
derrickc Wed, 03/26/2008 - 06:39
Good call....I should have caught that as I use object groups all of the time.
tdalago911, did this fix your problem?
