As5300 dialing to ISP
Mar 25th, 2008
I am trying to configure a AS5300 to dial to a ISP. I want to connect all the 120 modens with the ISP. I am trying to use GroupAsync and Dialer.
Is this the way, or how I can do this?
thanks
Makarand Chitale Wed, 03/26/2008 - 09:48
  • Cisco Employee,
Let me understand the setup in more detail for 120 modems to dialout to an ISP:
1. Are they going to form a ppp multilink bundle?
2. Are they all going to dial one number (say a 800 number) or more than one number?
3. Do we want all the modems to call out at once or keep adding modems based on the load on the link?
4. Do we have a PRI (T1 or E1) or CAS signaling on these lines?
Thanks, Mak
guilherme.bedin Wed, 03/26/2008 - 10:11
If possible it will be good, but isn't a requirement.
Yes, they all dial the same number.
I want all modems call out at once and stay connected. If is possible program all modems to stay connected from 13h to 18h for example.
But if isn't possible to schedule the call out and hang-up, I will be happy to stay always connected with all modems.
I have 4 E1 configured with:
controller E1 1
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
category 2
answer-signal group-b 1
Thanks for the help, let me known if you need more information.
Cheers,
Guilherme
Makarand Chitale Thu, 03/27/2008 - 11:30
  • Cisco Employee,
The below sample configuration is for modems say in group-range 1 - 120, note they are bound to Dialer 1 using dialer pool commands. If we have discontinuous group of modems then we can create another group-asyn interface and bind to the same dialer 1 using dialer pool command.
interface Group-Async1
!--- Interface to configure modems used for dialout.
no ip address
encapsulation ppp
!--- Use PPP encapsulation for members of this
!--- group-async interface.
dialer in-band
!--- Permit DDR on this interface.
dialer pool-member 10
!--- All members of this group-async interface belong
!--- to dialer pool 10.
ppp multilink
!--- Enable PPP multilink on physical interface.
group-range 1 120
!--- Assign async 1-120 to this group-async interface.
!--- This can be adjusted depending on the number of POTS lines available.
interface Dialer1
!--- Dialer interface to dialout to ISP.
ip address negotiated
!--- Obtain an IP address from central site.
encapsulation ppp
dialer pool 10
!--- Defines the pool of physical resources that the Dialer
!--- interface may use.
dialer idle-timeout 600
!--- Specifies number of seconds without interesting traffic that
!--- the connection is kept up.
dialer string 8001234567
!--- Number to be dialed; this number belongs to the PRI
!--- of the central router.
dialer load-threshold 15 either
!--- Load level for either inbound or outbound traffic
!--- at which additional lines will be added to the MP bundle.
!--- Load level values range from 1 (unloaded) to 255 (fully loaded).
dialer-group 8
!--- Uses dialer-list 8 to determine interesting traffic.
ppp authentication chap callin
!--- Use CHAP authentication for incoming calls only
!--- This router will not challenge remote routers for outgoing calls.
ppp chap hostname xxxx
ppp chap password yyyy
! --- This is the chap hostname/password the ISP needs to see
! --- Can also use PAP
ppp multilink
!--- Activates the interface for MP operation.
ppp timeout multilink link remove 300
!--- Keeps the multilink connections up for 300 seconds
!--- after the load drops below the threshold.
!--- This command should be used to control flapping.
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
!--- Use Interface Dialer1 for all networks.
dialer-list 8 protocol ip permit
line con 0
transport input none
line 1 120
modem InOut
transport preferred none
transport input all
Thanks, Mak
guilherme.bedin Fri, 03/28/2008 - 05:34
Hi Mak,
This is very close of what I have tried before. I tried this setup and still get the same problem as before, all the Async interfaces attached to the Dialer stay in Idle.
Like:
As1 - dialer type = IN-BAND ASYNC NO-PARITY
Dialer pool 10, priority 0
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is idle
How do I trigger something for them connect?
Do I need a chat-script in the line configuration? Like:
chat-script async "" "AT" OK "ATDT\T" TIMEOUT 30 CONNECT \c
Then, under your line 1, configure:
script connection async
modem dialout int async0/3/0
Thanks for the help.
Cheers,
Guilherme
Makarand Chitale Fri, 03/28/2008 - 07:54
  • Cisco Employee,
Guilherme, dialer remaining idle means possibly no call is being made out. It needs interesting traffic to initiate a call, the commands used for the same are as follows:
dialer-group x binds with dialer-list x, dialer-list states what is interesting traffic - in the above configuration any ip traffic is interesting (dialer-list 8 protocol ip permit), we can always fine tune to say what is interesting traffic and what is not. Also we need a route for the interesting traffic to go out (ip route 0.0.0.0 0.0.0.0 dialer 1).
Ideally a ping to say 100.100.100.100 (any ip other than one assigned to an interface on the router) should initiate a call out.
No, we do not need to configure a chat script (IOS uses a default chat script if one is not configured).
Please enable the following debugs:
debug dialer / debug chat / debug modem / debug cas for a ping to say 100.100.100.100
Thanks, Mak
guilherme.bedin Mon, 03/31/2008 - 04:56
Mak,
Bellow is one of the configurations that I tried. Even doing the ping from the as5300
don't initiate any call-out.
About the debug, I am accessing the as5300 by telnet and I don't see any debug message even enabling the debugs that you asked.
controller E1 0
framing NO-CRC4
cas-custom 0
country brazil
metering
category 2
controller E1 1
framing NO-CRC4
cas-custom 0
country brazil
metering
category 2
controller E1 2
framing NO-CRC4
clock source line primary
cas-custom 0
country brazil
metering
category 2
controller E1 3
framing NO-CRC4
cas-custom 0
country brazil
metering
category 2
interface Ethernet0
no ip address
no ip route-cache
shutdown
no clns route-cache
interface Serial0
no ip address
no ip route-cache
shutdown
clockrate 2015232
no fair-queue
no clns route-cache
interface Serial1
no ip address
no ip route-cache
shutdown
clockrate 2015232
no fair-queue
no clns route-cache
interface Serial2
no ip address
no ip route-cache
shutdown
clockrate 2015232
no fair-queue
no clns route-cache
interface Serial3
no ip address
no ip route-cache
shutdown
clockrate 2015232
no fair-queue
no clns route-cache
interface FastEthernet0
ip address 192.168.100.1 255.255.255.0
no ip route-cache
duplex full
speed 100
no mop enabled
no clns route-cache
no ip address
encapsulation ppp
dialer in-band
ppp multilink
no clns route-cache
group-range 1 120
interface Dialer1
encapsulation ppp
dialer pool 10
dialer idle-timeout 0
dialer string 0800000000
dialer load-threshold 1 outbound
dialer-group 8
ppp chap hostname [email protected]
ppp chap password 0 ******
ppp multilink
ppp timeout multilink link remove 65535
no clns route-cache
ip classless
no ip http server
snmp-server community public RO
line con 0
line 1 30
exec-timeout 0 0
modem InOut
modem autoconfigure type mica
modem dialout controller 0
rotary 1
transport preferred telnet
transport input all
transport output all
escape-character NONE
line 31 60
modem InOut
modem dialout controller 1
rotary 2
transport input all
line 61 90
modem InOut
modem dialout controller 2
rotary 3
transport input all
line 91 120
modem InOut
modem dialout controller 3
rotary 4
transport input all
line aux 0
line vty 0 4
password ******
login
Guilherme
Makarand Chitale Wed, 04/02/2008 - 15:29
  • Cisco Employee,
Guilherme, when doing a telnet session you will need to type in "terminal monitor" to see the debug outputs (terminal no monitor to stop the outputs).
Make sure the controllers are up and up and the MICA modems ok, do a "show modem" output.
You can also initiate an test call using reverse telnet to a modem and calling out using atdt:
telnet 192.168.100.1 3001 ( this is : telnet <3000+rotary group number>)
type AT << this should return an OK
type ATDTxxxxxxx where xxxx is the phone number
Let's see if the ATDT test generates any debugs or not, if it does then try the ping test from the router prompt.
Thanks, Mak
guilherme.bedin Thu, 04/10/2008 - 05:57
Hi Mak,
Thanks for the tips, but still with the same problem. The show modem and reverse telenet works fine, I can connect with the ISP with tem and a linux machine with ttyredirector. The debug messages when I do this is:
*Apr 10 11:50:23.836: TTY1: asserting DTR
*Apr 10 11:50:26.324: from Trunk(0):
DMFC: Got sig@ u125674 c0 tone25 group3
*Apr 10 11:50:26.328: from Trunk(0): (0/25): Tx SEIZURE (ABCD=0001)
*Apr 10 11:50:26.360: from Trunk(0): (0/25): Rx SEIZURE_ACK (ABCD=1101)
*Apr 10 11:50:37.928: from Trunk(0): (0/25): Rx ANSWERED (ABCD=0101)
*Apr 10 11:50:54.088: TTY122: timer type 1 expired
*Apr 10 11:50:54.088: TTY122: Exec timer (continued)
*Apr 10 11:52:10.092: from Trunk(0): (0/25): Tx IDLE (ABCD=1001)
*Apr 10 11:52:10.128: from Trunk(0): (0/25): Rx IDLE (ABCD=1001)
*Apr 10 11:52:14.484: tcp1: conn not alive
*Apr 10 11:52:14.484: TTY1: no timer type 2 to destroy
*Apr 10 11:52:14.484: TTY1: Line reset by "TTY Daemon"
*Apr 10 11:52:14.484: TTY1: Modem: (unknown)->HANGUP
*Apr 10 11:52:14.484: TTY1: no timer type 0 to destroy
*Apr 10 11:52:14.484: TTY1: no timer type 1 to destroy
*Apr 10 11:52:14.484: TTY1: no timer type 3 to destroy
*Apr 10 11:52:14.484: TTY1: no timer type 4 to destroy
*Apr 10 11:52:14.484: TTY1: no timer type 10 to destroy
*Apr 10 11:52:15.092: TTY1: dropping DTR, hanging up
*Apr 10 11:52:15.092: tty1: Modem: HANGUP->IDLE
*Apr 10 11:52:16.604: %CALLRECORD-3-MODEM_CALL_REC_ERROR: DS0 slot/contr/chan=0/0/25, slot/port=1/0, call_id=8E58, userid=(n/a), ip=0.0.0.0, calling=(n/a), called=08000000, std=V.34+, prot=LAP-M, comp=V.42bis both, init-rx/tx b-rate=33600/33600, finl-rx/tx b-rate=33600/33600, rbs=0, d-pad=None, retr=0, sq=2, snr=39, rx/tx chars=806/736, p/w info=0, rx/tx ec=32/77, bad=0, time=91, finl-state=Steady, disc(radius)=none/No Reason, disc(modem)=8220 Rx (line to host) data flushing - OK/EC condition - locally detected/received DISC frame -- normal LAPM termi
*Apr 10 11:52:20.108: TTY1: restoring DTR
*Apr 10 11:52:21.108: TTY1: autoconfigure probe started
But with the dialer still nothing. The Group async and dialer configuration is:
no ip address
encapsulation ppp
dialer in-band
ppp multilink
no clns route-cache
group-range 1 5
interface Dialer1
encapsulation ppp
dialer pool 10
dialer-group 8
ppp chap hostname username
ppp chap password 0 xxxxxxx
ppp multilink
no clns route-cache
ip classless
no ip http server
Don't appear anything in the debug messages even when I do a ping in 100.100.100.100. But the show dialers seems to be correct.
as5300#show dialer
As5 - dialer type = IN-BAND ASYNC NO-PARITY
Di1 - dialer type = DIALER PROFILE
Load threshold for dialing additional calls is 1
Idle timer (never), Fast idle timer (20 secs)
Number of active calls = 0
Dial String Successes Failures Last DNIS Last status
0800000 0 0 never - Default
Gr1 - dialer type = IN-BAND ASYNC NO-PARITY
Is there a way to force dialers to connect?
thanks for the help.
Guilherme
