7985 isuue
Mar 25th, 2008
my 7985 iphone can not dial the pstn.but
others is no problem.CCS and partion is ok! there is my debug:
26 03:23:39.830: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0122
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Calling Party Number i = 0x0181, '20050'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '7037531'
Plan:Unknown, Type:Unknown
*Mar 26 03:23:40.114: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8122
Channel ID i = 0xA9839E
Exclusive, Channel 30
*Mar 26 03:23:41.274: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8122
Cause i = 0x84B7 - Unknown cause value
*Mar 26 03:23:41.278: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0122
Cause i = 0x80E4 - Invalid information element contents
*Mar 26 03:23:41.346: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8122
Kenneth Mohammed Wed, 03/26/2008 - 11:56
  • Silver, 250 points or more
7985 sets are going to try to setup a video call by default. Therefore, under the voice-port config in your gateway, you should put the statement "bearer-cap Speech". This should resolve your issue.
If you found this helpful kindly remember to rate this post.
