VPN client error 422, when using wireless
Mar 25th, 2008
I installed the Cisco VPN client version 5.0.02.0090 on a fresh install of WinXP/SP2 and when the PC is connected via ethernet to my DSL router, I can VPN just fine. When I disconnect from ethernet and use wireless to the DSL router, within seconds of brining up the VPN tunnel it is torn down with the dreaded 422 error "Secure VPN connection terminated locally by the Client. Reason 422:Lost contact with the security gateway. Check your network connection"
The client log shows the underlying IP address changes after Address watch is initiated, to the IP address that our headend concentrator gives out to VPN clients. Then the errors start to show up in the log like:
87 22:08:53.234 03/26/08 Sev=Warning/3 IKE/0xE3000069
Failed to send 76 bytes to xxx.xx.xxx.xx (the IP of out headend concentrator), error = 0xFFFFFFF0
88 22:08:53.234 03/26/08 Sev=Info/5 IKE/0x63000018
Deleting IPsec SA: (OUTBOUND SPI = A553FFB INBOUND SPI = 574F7608)
89 22:08:53.234 03/26/08 Sev=Info/4 IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=17610B7E
90 22:08:53.234 03/26/08 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=6777C38CD571D27F R_Cookie=7F54F6FE73061972) reason = DEL_REASON_ADDRESS_CHANGE
...then lots of errors in log as phase I, keys and everything else is deleted.
This is repeatable every time I load the VPN client while I'm using wireless. The wireless adapter is a Realtek USB adapter. I've googled error 422 and other people are getting the same problem, but there is no solution, and most cases are when users are on Windows Vista.
Is this a known Cisco problem and is there a fix for it?
markus.jahnke Wed, 03/26/2008 - 00:21
Is there a firmware upgrade available for your router? Sometimes it's usefull to enable the "IPSec/VPN passthrough" option on your router.
And, if configured on the concentrator, you may enable nat-traversal, udp or tcp encapsulation for the vpn traffic in the vpn client.
