Problem in Object Tracking On a Cat 6509
Mar 25th, 2008
Hello All,
I want to configure object tracking on Cat 6509, the sample configuration is provided below..I am not able to configure a portion of the command shown in inverted commas.
interface VlanX
ip address x.x.x.x 255.255.255.x
ip policy route-map PBR
route-map PBR permit 10
set ip next-hop verify-availability "192.168.0.10 10 track 123"
set ip next-hop verify-availability "192.168.1.20 20 track 124"
control-plane
rtr 1
type echo protocol ipIcmpEcho 4.2.2.3
rtr schedule 1 life forever start-time now
rtr 2
type echo protocol ipIcmpEcho 4.2.2.4
rtr schedule 2 life forever start-time now
track 123 "rtr 1 reachability"
track 124 "rtr 2 reachability"
Here's the sh ver of cat 6509 :--------->
ND-GF-S6509-01#sh ver
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17d)SXB11a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 13-Apr-06 04:50 by kehsiao
Image text-base: 0x40020FBC, data-base: 0x41F18000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17d)SXB11a, RELEASE SOFTWARE (fc1)
ND-GF-S6509-01 uptime is 14 weeks, 4 days, 13 hours, 15 minutes
Time since ND-GF-S6509-01 switched to active is 14 weeks, 4 days, 13 hours, 14 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by reload)
System restarted at 07:51:34 GMT Fri Dec 14 2007
System image file is "sup-bootflash:/s72033-pk9sv-mz.122-17d.SXB11a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-E (R7000) processor (revision 1.2) with 458752K/65536K bytes of memory.
Processor board ID SMC1026002Z
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
4 Ethernet/IEEE 802.3 interface(s)
25 Virtual Ethernet/IEEE 802.3 interface(s)
144 FastEthernet/IEEE 802.3 interface(s)
74 Gigabit Ethernet/IEEE 802.3 interface(s)
4 Ten Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
I HAVE ALSO ATTACHED THE SCREEN SHORTS OF THE CONFIGURATION PROCESS....
Rohit
