Problem with router 1841 and Module card Hwic-1FE
Mar 26th, 2008
Dear All,
Could you tell me please, i have router cisco 1841 and Module card Hwic-1FE.when plug Hwic-1FE to router and i type command show run i don't see interface Hwic-1FE on Router 1841.What is going on ?
Note:i used this IOS : c1841-ipbase-mz.124-1c.bin
Best Regards,
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 03/26/2008 - 03:00
You need a later IOS for that card, I recommend 12.4(11)XJ4.
If you don't have the support contract required to download the image from CCO, either buy a service contract or ask who has sold you router/card to provide it to you.
rechard_david Wed, 03/26/2008 - 18:18
Dear sir,
Thank you for your advices!!!
Ok i understood. Could you give more detail part number that can support command load balancing.
one more when i plug card to the router are three LEDs port is up(mean light is on are three port are up)
Note: i not yet plug network cable to module card.
Best Regards,
Paolo Bevilacqua Wed, 03/26/2008 - 18:26
No part numbers. Load balancing is embedded in IOS and just a matter of configuration.
As a recognition to those providing answers, please rate useful posts with the scrollbox below!
