Using Different VLANs within a MPLS VRF
Mar 26th, 2008
My company has a couple of clients that have similar network requirements that need to transverse our IP/MPLS core. We are looking at the possibility of grouping these clients within the same VRF and use VLANs to separate their traffic.
I would need advice on the best possible way to achieve this.
royalblues Wed, 03/26/2008 - 05:44
  • Green, 3000 points or more
If you need to group your clients into a single VRF, all you need to do is to just define the VRF on the PE under the interface towards the CE.
Vlans can be defined on the switch as you would do in a normal campus network.
If you need to have seperation throughout, you can use vrf lite at the campus and use different vrfs for each client
Narayan
Harold Ritter Sat, 03/29/2008 - 06:05
  • Cisco Employee,
Olubunmi,
Bear in mind that even if these customers are on different vlans, they will still have access to each others network at layer 3 as they will be terminating in the same VRF. Probably not something you want.
shivlu jain Sat, 03/29/2008 - 08:30
  • Silver, 250 points or more
ip vrf abc
rd 1:1
rt both 1:1
interface GigabitEthernet0/3.204
encapsulation dot1Q 204
ip vrf forwarding abc
ip address 10.16.170.69 255.255.255.252
end
interface GigabitEthernet0/3.205
end
regards
shivlu
