WAN switching
Answered Question
Mar 26th, 2008
Hi i have gateway 2811 and 2 internet provider. As i can make, when 1 provider disconect internet automatic switching on port 2 provider. And when connect with 1 provider resume internet switching on port 1 provider.
Correct Answer by Giuseppe Larosa about 8 years 9 months ago
Hello sun,
if you want to use PBR = policy based routing you need to apply it on the inside interface.
In fact, with your configuration you are checking if the source address is in the server address block or if it is in the user block.
Move the command ip policy route-map univer command under the inside interface
hope to help
Giuseppe
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
Begin with two static routes (one can have an better metric if you do not want load-balancing)
) and two nat statements. Once you are in the situation where you can shutdown either interface, clear nat translations, and things continue to work, you go for the second part (ip sla).
The initial example is:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
the advanced one is:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Good luck!
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Wed, 03/26/2008 - 07:34
That is not an easy configuration. Do you have enough expereince to read and interpret examples and adapt them to your needs ?
sun_sazanov Wed, 03/26/2008 - 08:45
yes. I think that I would have enough experience what to adapt examples under the requirements
Correct Answer
Paolo Bevilacqua Wed, 03/26/2008 - 09:39
Good luck!
sun_sazanov Fri, 05/16/2008 - 01:08
Hi.
I want for user 10.10.10.0/24 goto internet over 1 isp, 10.10.11.0/24 over 2 isp.
I have next configuration.
interface GigabitEthernet0/1.1
description $ETH-LAN$
encapsulation dot1Q 102
ip address 92.255.X.XXX 255.255.255.252
ip access-group sdm_gigabitethernet0/1.1_in in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly
ip policy route-map sety
interface GigabitEthernet0/1.2
encapsulation dot1Q 101
ip address 195.70.X.XXX 255.255.255.240
ip access-group 142 in
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 195.70.X.YYY
ip route 0.0.0.0 0.0.0.0 92.255.X.YYY
ip nat inside source route-map sety interface GigabitEthernet0/1.1 overload
ip nat inside source route-map univer interface GigabitEthernet0/1.2 overload
ip access-list standard Serv
remark Nat for server
remark SDM_ACL Category=2
permit 10.10.10.0 0.0.0.255
ip access-list standard User
permit 10.10.11.0 0.0.0.255
route-map univer permit 10
match ip address Serv
set ip next-hop 195.70.X.YYY
route-map sety permit 10
match ip address User
set ip next-hop 92.255.X.YYY
But this configuration, not work. You can help me with this problemm.
Correct Answer
Giuseppe Larosa Fri, 05/16/2008 - 01:47
Hello sun,
hope to help
Giuseppe
sun_sazanov Tue, 05/20/2008 - 00:14
Hi.
In my network work next sheme.
traffic network 10.10.10.0/24 and 10.10.11.0/24 collect on 3750 and goto on 2821 with ip 10.10.4.1 and goto internet.
And if i move commad ip policy route map univer under interface with ip 10.10.4.1 it's not work.
As still it is possible to make distribution of the traffic between ISP? for network 10.10.10.0 --> ISP1 and network 10.10.11.0 --> ISP2
