Brandon Buffin Wed, 03/26/2008 - 07:43
Can you post your config as well as the domain name entered for your gateway in CCM config?
Brandon
Brandon Buffin Wed, 03/26/2008 - 08:11
From "R01801.interior.gov.bh" in the debug, it appears that you have a domain name configured on the gateway. Be aware that this domain name must appear in the CCM config as well. You cannot simply use R01801.
Hope this helps.
Brandon
sandeep pokhriyal Wed, 03/26/2008 - 08:49
ya i tried both adding and removing ip domain from router and CCM but still the same issue with other routers its working.. donno whts wrong with this one.
mattcalderon Wed, 03/26/2008 - 08:11
After looking at your debug, you have verified that your gw name in ccm is R01801.interior.gov.bh ?
sandeep pokhriyal Wed, 03/26/2008 - 09:52
Zin.Karzazi Wed, 03/26/2008 - 10:12
do a "no mgcp" then "mgcp" again, see if that could bring the GW to register.
please also post the "show ccm-manager" output.
sandeep pokhriyal Sat, 03/29/2008 - 22:59
hi,
I am able to register the gateway.
i just registered one of the port of gateway on the callmanager and it worked like it should have...
thanks for all your contributions.
