Cisco ASA 5510 Remote VPN Connection Drop in 20 minutes
Mar 26th, 2008
I'm using an ASA 5510 (8.03ED) firewall and configured with Remote VPN Client (IPSec). The connection could be established successfully, but it will be disconnected after 20 minutes (Sharply), and then I will not be able to ping the Firewall Outside Interface anymore plus not able to establish the VPN connection again UNTIL I reboot the firewall.
Anyone met this problem also?
johnd2310 Wed, 03/26/2008 - 13:52
  • Silver, 250 points or more
Are you seeing anything in the logs on the ASA?
John
