IPCC_DC Directory
Mar 26th, 2008
I am 2 ipcc servers working in fail over version 4.04 integrated with 2 callmanagers pub and sub version 4.13
is it correct that if the publisher was off line then a number of services would not fuction on the ipcc servers? i.e I could not add or update scripts when the publisher is down?
lpezj Wed, 03/26/2008 - 09:29
If the publisher fails you can not add any configuration to CallManager. So, IPCC Express can goes on working, but you can not add new configuration.
Hope this helps,
Juan Luis
jamjam200 Wed, 03/26/2008 - 15:24
yes I understand that if the publisher is down no changes can be made to CM but my question is can changes be made to ipcc i.e can I still update scripts
