Remote upgrade ES release for CUPS 6.0
Mar 26th, 2008
Is there a way to upgrade to the ES release via the browser? I have the server in a colo and had to do a rebuild through the KVM. I would have to send someone there to put the CD in to run the upgrade. Is there an alternate method? FTP came back as unknown error when I tried it during the install and had to back out of applying patches to complete the install.
pklos Thu, 03/27/2008 - 09:19
  • Silver, 250 points or more
I've installed UCSInstall_UCOS_ES_6.0.2.1101-1.sgn.iso via browser (patch file on ftp server) and everything was OK. Maybe you had ftp transfer problem?
regards,
PK
tahequivoice Thu, 03/27/2008 - 09:35
I attempted to do it during the install where it failed miserably. The iso file should work through the GUI upgrade? I will give it a try. Thanks, will let you know if I am successful.
neil.woolloff Sat, 06/28/2008 - 07:22
how did you get on with applying the iso through the gui, as i can see no way of doing this and need to apply an es.
any advice is appreciated.
I do not wish to go through a rebuild and say yes at the section to apply as surely this will destroy the current configuration etc
