inspect ftp on 5520
Mar 26th, 2008
configuring my new 5520 and ran the output interperte on it. states : WARNING: FTP inspection engine is disabled. Outbound users will be able to start
connections only in passive mode, and all inbound FTP will be disabled.
TRY THIS: Enable FTP inspection engine using the 'inspect ftp' command in class
configuration mode
im sure this isnt complicated, but some of the commands I found on cisco site arent working..... please advise
thanks
i-kendall Tue, 04/01/2008 - 03:54
Near the very bottom of the config, it should have the following
policy-map global_policy
class inspection_default
inspect ftp
If the inspect command is not present, and your question implies it is not, then add these three lines in config mode, and it should be fixed.
If not, then post the config, and I will take another look.
Iain
