husycisco Wed, 03/26/2008 - 13:43
Hi Mark
All you have to do is defining 1 single IP entry or the interface itself in the following section
global (outside) x ipaddresshere or
global (outside) x interface
gmtimmons Fri, 03/28/2008 - 06:59
so basicaly a
global (outside) id ousideip.2-outsideip.7 netmask x.x.x.x can be replaced with
global (outside) id outsideip.2
husycisco Fri, 03/28/2008 - 08:00
Exactly. If it fails, try
global (outside) id outsideip.2 netmask 255.255.255.255
smohanasundaram Fri, 05/02/2008 - 02:48
try with this config
for Example
nat (inside) 1 172.16.0.0 255.255.0.0
global (outside) 1 "outside Ip"
hopes this helps
regs
S.Mohana sundaram
