marahman78 Wed, 03/26/2008 - 22:05
Yes, i've checked and i make a new custom tone but it didn't resolved my problem. Please advice.
paolo bevilacqua Thu, 03/27/2008 - 02:36
  • Hall of Fame,
    Founding Member
Record your tone on the PC, attach it here together with config and mentioen the applicable country.
marahman78 Thu, 03/27/2008 - 04:25
Please find the attached tone & config file. Country = Pakistan. Also find the debug file.
MAR
paolo bevilacqua Thu, 03/27/2008 - 05:18
  • Hall of Fame,
    Founding Member
Hi, recording quality is marginal, but try 440 Hz, 275 ms on 275 ms off.
marahman78 Fri, 03/28/2008 - 06:52
I've checked but it didn't work. Please find the attached "debug vpm all" file. I'll be waiting for your useful suggestion.
marahman78 Mon, 03/31/2008 - 04:39
I've tried but no luck. Is there any way to find out which type of signals PSTN are sending.
MAR
paolo bevilacqua Mon, 03/31/2008 - 05:18
  • Hall of Fame,
    Founding Member
It's probably 425 Hz after all. The recording you sent has a lot of noise and the frequency analysis can be impacted. The main problem is that tone-based is unreliable in itself.
marahman78 Wed, 04/02/2008 - 08:14
Is there any way to find out which type of signals PSTN are sending ?
paolo bevilacqua Wed, 04/02/2008 - 08:17
  • Hall of Fame,
    Founding Member
They are sending the signals detailed above, problems is rotuter doesn't recognize them. Which exact IOS are you using ?
marahman78 Wed, 04/02/2008 - 23:14
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(3h), RELEASE SOFTWARE (fc2)
c2800nm-adventerprisek9-mz.124-3h.bin
paolo bevilacqua Thu, 04/03/2008 - 08:01
  • Hall of Fame,
    Founding Member
That "might" be CSCek27376. Do you use "connection plar XXX" or "connection plar opx XXX", and can you switch to the second if using the first ?
marahman78 Sat, 04/05/2008 - 02:49
I've checked but no output. So anyway thanks. You did'nt tell me how to check the PSTN signals?
paolo bevilacqua Sat, 04/05/2008 - 03:12
  • Hall of Fame,
    Founding Member
No output for what ? We've checked the PSTN signals already.
marahman78 Sun, 04/06/2008 - 21:24
What i meant to say is that i've checked but it's not working.
