IPM V2.6 - CSCsj06260 re-posted
Mar 26th, 2008
I noticed CSCsj06260 was posted on the site and then was gone a few days later. It now is re-posted with a Mar 25 date and the modules are of different file size. I assume this should be re-downloaded and re-applied. Never have re-applied a patch before. Any process concerns or just re-un script ? thanks
Joe Clarke Wed, 03/26/2008 - 09:39
It would be safest to re-apply, yes. Re-application is simple. Just repeat the exact same steps you did previously.
