isdn error msg on cisco 2811 w/ voip card..vwic
Mar 26th, 2008
hi guys, i have configured the 2811 with a pri-group,dial-peer,destination........(10 digits..2811 is connected to a voice server/isdn-pri which originates the call and passes it on to the 2811, my target ip is 192.168.x.x,which is a multitech(voip gateway)already in my network connected to a juniper..
Problem:I get an error msg:Cause i = 0x82A6 - Network out of order...
I can ping the 2811 from the multitech, but cannot ping the multitech from the 2811....any ideas, do i have to define any type of route in the cisco2811.
CIA2811_UK-VOIP#deb isdn q931
debug isdn q931 is ON.
CIA2811_UK-VOIP#
000437: *Mar 26 12:15:55.431 PCTime: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0008
Bearer Capability i = 0x8090
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808381
Exclusive, Interface 0, Channel 1
Net Specific Fac i = 0x00E3
Calling Party Number i = 0x2180, '9933000'
Plan:ISDN, Type:National
Calling Party SubAddr i = 0x80, 'P123'
Called Party Number i = 0xA1, '9734390088'
Called Party SubAddr i = 0x80, 'P456'
Plan:Unknown, Type:Unknown
000438: *Mar 26 12:15:55.451 PCTime: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8008
Channel ID i = 0xA98381
Exclusive, Channel 1
000439: *Mar 26 12:15:55.459 PCTime: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8008
000440: *Mar 26 12:15:55.471 PCTime: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0008
Cause i = 0x80A6 - Network out of order
000441: *Mar 26 12:15:55.475 PCTime: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8008
Paolo Bevilacqua Wed, 03/26/2008 - 15:03
Hi since we can't know your network topology, you need to revise it until you can ping anything from everywhere. Then things will work.
Separately, I would be curious to know how you can generate a call with subaddress "P456".
