2960/2950 cluster conversion
Mar 26th, 2008
Hi, I have a cisco 2960 as the commander switch with an ip address that is reachable on vlan10 'I had to change the cluster management vlan to 10'. The other 4 switches are 2050's, and are all in a cluster.
When I try using the CNA cluster conversion wizard, I get a 'failed to connect'. My best guess is that the rest of the switches are using vlan 1 as the management cluster vlan?
Any suggestions appreciated
jason.
avtechs19 Wed, 03/26/2008 - 12:50
Hi, It would seem that all switches must be using the same management-vlan. Here is one point I do not understand.
Using the cli I could not change the management-vlan, it would give me a error stating that only this could only be done on a command switch. I tried changing it using the cna and it worked?
jason
