Limiting Access within Cisco CallManager Administration (4.1)
Answered Question
Is it possible to limit access within the Cisco CallManager Administration web interface. We want to allow our support technicians to change a user's password and PIN, but not be able to make other changes to the Callmanager. Thank you
Correct Answer by Rob Huffman about 9 years 1 month ago
Hi Eric,
This is most possible using MLA (Multi Level Admin);
Multilevel Administration Access
Multilevel administration access provides multiple levels of security to Cisco CallManager Administration. This technique permits granting only the required privileges for a selected group of users and limits the configuration functions that users in a particular user group can perform.
Prior to the availability of multilevel administration access, administrators with read/write access to Cisco CallManager configuration could change any or all the database/directory elements that are accessible through Cisco CallManager Administration and Cisco CallManager Serviceability. Users could inadvertently disable the entire system with a few mouse clicks by accidentally modifying the data to which they do not need access.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmsys/a02mla.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 03/26/2008 - 10:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Eric,
Hope this helps!
Rob
