03-26-2008 12:30 PM - edited 03-05-2019 09:59 PM
2-port OC-48c POS SM Model OSM-2OC48/1DPT-SS is automatically being powered down with IOS 12.2(33)SXH1 on a CAT 6509-E, but comes up fine with older version 12.2(18)SXF6.
I couldn't find any known bugs, but maybe I missed it somewhere.
Any help would be appreciated
Solved! Go to Solution.
03-26-2008 01:11 PM
I'm not an expert on OSM's but according to the release notes for 12.2(33)SXH all Optical Service Modules are unsupported hardware so you would have to revert back to 12.2(18)SXF for those modules to work.
Jon
03-26-2008 01:11 PM
Jon
03-26-2008 01:14 PM
Jon,
But this IOS is SXH1, which is a newer release. Now looking for the SXH1 release notes.
Thanks for pointing me in the right direction, though.
Richard
03-26-2008 01:21 PM
Richard
From the doc i gave a link to
"Release 12.2(33)SXH and later releases do not support the following hardware"
So it looks like the whole 12.2(33)SXH train will not support OSM's.
Jon
03-26-2008 01:33 PM
Jon,
I looked deeper in the "Release Notes for Cisco IOS Release 12.2(33)SXH and Later Releases":
It states that Release 12.2(33)SXH and LATER releases do not support the following hardware:
Optical Services Modules (OSMs)
I went further down and found a listing for: New Hardware Features in Release 12.2(33)SXH1
They only listed the below devices and did not list any OSMs. So, it can only mean that the OSM
was not set for support with SXH1.
â¢Anomaly Guard Module (WS-SVC-AGM-1-K9)-See this publication:
http://www.cisco.com/univercd/cc/td/doc/product/secure/ad_g/jaffa/jaffaagd.htm
â¢Traffic Anomaly Detector Module (WS-SVC-ADM-1-K9)-See this publication:
http://www.cisco.com/univercd/cc/td/doc/product/secure/ad_g/jaffa/jaffatad.htm
Thanks!!
