I am trying to run a test config job to puch an archived config up to a test router.
The router is in Cisco Works and the config has been archived successfully.
When I try to push a config up to the router using
Config Mgmt\Config Editor\Config Editor Jobs
I get rhis error:
"CEDT0031: No command is available to download for the device test_router. Remove the device from job and try again."
My goal is to quckly push an existing config up to a device that has failed and is replaced with a new router.
