Manual Sophos Updates
Mar 26th, 2008
Is there a way that I can manully download the Sophos antivirus updates and then upload onto my appliance? This is because, I am getting some update errors even at night when I feel the networks will be less congested.
staylor_ironport Wed, 03/26/2008 - 22:21
As far as I am aware this is a NO, the only function that can be downloaded manually is the AsyncOS firmware, in regards to the AV/AS/VOF you really need these to be updated on the 5 minute interval to make sure that you are fully protected.
You don't really get any benefit from doing it manually, if it's erroring all the time at night then I would recommend you log a support ticket
