NAT error message
Mar 26th, 2008
folks
i have an internet facing 2600 router in front of a 515 pix cluster
the 2600 nats incoming traffic from ANY host to an internet routable address (destination port 25) and routes it to an internal mail server
i can see the translation table and the nat is working ok
the pix receives the inbound traffic to a specific host on a dmz interface and should apply an acl which allows ANY host to connect to the internal address
however, the pix is complaining with the following error
Mar 26 16:21:59 145.a.a.a Mar 26 2008 14:29:46 Clar-PIX-1 : %PIX-2-106001: Inbound TCP connection denied from 213.b.b.b/2746 to 145.c.c.c/25 flags SYN on interface outside
Mar 26 16:21:59 145.a.a.a Mar 26 2008 14:29:46 Clar-PIX-1 : %PIX-3-305005: No translation group found for tcp src outside:213.b.b.b/2746 dst dmz:145.c.c.c/25
can anyone give me a clue or an idea of what the problem is?
thanks to anyone taking the time to reply
johnd2310 Wed, 03/26/2008 - 14:24
  • Silver, 250 points or more
hi,
you need to configure nat and statics on the pix. If the pix is not doing any address translation then set NAT0.
John
mulhollandm Wed, 03/26/2008 - 14:32
john
many thanks for your reply
i have a nat for the specific internal host as follows
static (dmz,outside) 145.c.c.c 145.c.c.c netmask 255.255.255.255 0
i also have following
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
thanks for your help
