AIR-ANT2506 ... Can it be mounted up-side-down?
Mar 26th, 2008
Just wondering if I'd lose any signal strength if I was to mount the AIR-ANT2506 in the up-side-down position.
The reason I want to do this is that currently we have an AIR-ANT2506 mounted to the side of an outdoor enclosure, where it sits raised above the enclosure. But I feel that the enclosure is mounted a bit too high, so I thought about mounting the antenna in the 'hanging' position from the enclosure to lower the position of the antenna.
Can the AIR-ANT2506 be mounted in this way without any consequence?
Overall Rating: 3 (1 ratings)
Rob Huffman Wed, 03/26/2008 - 16:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
The 2506 can be mounted in an inverted position but you do run the risk of it filling up with water if exposed to moisture;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbfde67
Hope this helps!
Rob
JolietJake Wed, 03/26/2008 - 17:14
Thanks Rob,
I think I'll try getting the AP enclosure lowered rather than mount the antenna inverted.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
