CME QCT toll does not recognize T1/E1 card
Mar 26th, 2008
When I use the "Auto detec hardware" option in the 3.1 QCT tool, it finds the Unity Express & 4 port FXO but it does not detect the T1/E1 card. The router is a 2821 CME 4.0 and CUE 3.0. Is this normal or should it detect it?
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 03/26/2008 - 16:51
  • Hall of Fame,
    Founding Member
Hello, a friendly advice, for professional results and more importantly to understand what you're doing, forget qct and gui tools and only use cli to configure CME. In particular the T1/E1 card only requires 4-5 commands that I can summarize here for you if you tell us where you are and which telco service you got.
sean.reardon Wed, 03/26/2008 - 17:00
In the US. It's an AT&T T-1. ISDN PRI 23 channels. Here is what shows up in the CLI output form the QCT tool
card type t1 0
card type t1 0 0
isdn switch-type primary-4ess
controller t1 0/0/0
default mode
line b8zs
framing esf
clock source line
pri-group timeslots 1-23
no shutdown
Sean
paolo bevilacqua Wed, 03/26/2008 - 17:31
  • Hall of Fame,
    Founding Member
A "corrected" config would be:
card type t1 0
network-clock-participate wic 0
network-clock-select 1 t1 0/0/0
isdn switch-type primary-5ess
controller t1 0/0/0
no shutdown
dial-peer voice 100 pots
desc ld calls
destination-pattern 91[2-9][0-8][0-9][2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 101 pots
desc lata calls
destination-pattern 9[2-9]......
forward-digits 7
port 0/0/0:23
dial-peer voice 102 pots
desc international
destination-pattern 9011......T
port 0/0/0:23
prefix 011
dial-peer voice 103 pots
desc *11
destination-pattern 9[2469]11
port 0/0/0:23
forward-digits 3
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:23
forward-digits 3
The config for DP is a bit verbose but will allow you to:
1- prevent misdialed calls by strict nanp checking
2- count how many calls are done and where with "show dial-peer voice"
3- enforce limitations based on calling phone for what is callable and what is not.
You will find that CME is a very powerful PBX but it takes some time to master it. it's time well spent anyway.
sean.reardon Thu, 03/27/2008 - 09:46
Paulo,
Great advice. Works like a champ Calls now ring into the phones. One more question: Calls come into the system fine but when I dail 91(xxx)xxx-xxxx I am getting a busy signal. Does the config you provided handle outcalling or is that something I need to fiddle with in the user parameters?
paolo bevilacqua Thu, 03/27/2008 - 10:06
  • Hall of Fame,
    Founding Member
Well the idea was a to give you a config for outcalling ...
can you take "debug isdn q931" with "term mon" when you make an outgoing call ?
sean.reardon Fri, 03/28/2008 - 09:38
Paulo/ anyone,
Here is the output from the ISDN Debug Q931. I tried to dial a 10 digit #/ As you see the error is: Cause i = 0x83E020 - Mandatory information element missing. Any suggestions?
debug isdn q931 is ON.
Singapore#
Mar 28 12:31:36.999: ISDN Se0/0/0:23 Q931: Applying typeplan for sw
0x2 0x1, Calling num 80001
Mar 28 12:31:37.003: ISDN Se0/0/0:23 Q931: Applying typeplan for sw
0x2 0x1, Called num 19788771761
Mar 28 12:31:37.003: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 call
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2180, '80001'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '19788771761'
Mar 28 12:31:37.047: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd =
0x8087
paolo bevilacqua Fri, 03/28/2008 - 15:26
  • Hall of Fame,
    Founding Member
Hi, somewhere in the config, do have a command that sets "ISDN national" ? If so, please remove it. Also please add:
int serial 0/0/0:23
isdn sending-complete
