CME 3.2 and Conf / Call Bridge
Mar 26th, 2008
I have CME 3.2, on a 2821 running ver 12.4. I have both 7940G and 7936 phones and need to somehow create the ability for a conference/call bridge where users (all using voip) can dial in, no more than 48 total. They all go through the same 2821 router. Someone told me that I would have to get at least Unity Express AIM ver 3.1 to accomplish this. Can anyone assist?
Paolo Bevilacqua Wed, 03/26/2008 - 16:55
  • Hall of Fame,
    Founding Member
Hi, higly recommend you upgrade to 4.1 w/ IOS 12.4(11)XJ4.
That will give you the ability of creating multiparty conferences or bridges so to say, that are based on DSP hardware. Before that IOS/CME, a dual-port T1/E1 with a cross connection is required, that is a cumbersome solution.
glenn-mchenry Wed, 03/26/2008 - 16:58
So instead of getting Unity Express AIM 3.1, just upgrade CME to 4.1 and my IOS to 12.4(11)XJ4 will allow me to do a true conf bridge where people can dial in and not have to be added in by calling each individual?
Paolo Bevilacqua Wed, 03/26/2008 - 17:40
  • Hall of Fame,
    Founding Member
Yes, and you can have fancy functions like list who's in the call, play nice sounds when they join in, etc.
Only missing thing to a professional service is a pin-driven front-end to the bridges but someday that I'm in the mood I shall write some TCL/IVR script for that. I will also have the name recorded and announce at join time, thing that I find a little annoying but hey that makes people sound important.
Rob Huffman Wed, 03/26/2008 - 17:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Glenn,
Just to add a note to the good info from Paolo. Here is the config info for CME;
SCCP: Configuring Multi-Party Ad Hoc and Meet-Me Conferencing in Cisco Unified CME 4.1 and Later Versions
To configure multi-party ad hoc conference support for 3-8 parties plus Meet-Me conferencing for up to 32 parties;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1020601
Hope this helps!
Rob
kadambari.beelw... Thu, 06/26/2008 - 10:16
I have following config on cme
voice class custom-cptone jointone
dualtone conference
frequency 1200 1200
cadence 150 50 150 50
--More-- !
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729br8
codec g729r8
maximum sessions 2
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
telephony-service
sdspfarm conference mute-on 111 mute-off 222!
sdspfarm units 1
sdspfarm tag 1 mtp761076107610
conference hardware
load 7965 SCCP45.8-3-2S
load 7945 SCCP45.8-3-2S
load 7936 cmterm_7936.3-3-5-0
max-ephones 58
max-dn 192
ip source-address 3.156.91.1 port 2000 secondary 3.156.91.2
--More-- calling-number initiator
service phone videoCapability 1
timeouts interdigit 6
system message USHE
url services http://3.156.91.4/voiceview/common/login.do
url authentication http://3.156.91.4/voiceview/authentication/authenticate.do
time-zone 8
keepalive 10
voicemail 8688
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name cisco password cisco
dn-webedit
ephone-template 1
conference drop-mode creator
conference add-mode creator
conference admin
softkeys hold Join Newcall Resume Select
softkeys idle ConfList Gpickup Join Login Newcall Pickup Redial RmLstC
softkeys seized Redial Endcall Cfwdall Pickup Gpickup Callback Meetme
softkeys connected Hold Trnsfer Park Endcall Confrn ConfList Join Select RmLstC
but my phones are unable to conference,
I get following error when I turn on debugs
1681756: Jun 25 20:02:20.960: SkinnyAddDnToHwConference: phone=2 (dn=34 chan=1 s
tate=9) (conf_dn=34 conf_chan=2 state=4)
1681757: Jun 25 20:02:20.960: SkinnyGetCallState for DN 34 chan 2 CONNECTED
1681758: Jun 25 20:02:20.960: called DN -1 chan 1, calling DN -1 chan 1 phone 3
s2s:0
1681759: Jun 25 20:02:20.960: SkinnyAddDnToHwConference: New adhoc conference
1681760: Jun 25 20:02:20.960: skinny_hwcfb_get_adhoc_number:
1681761: Jun 25 20:02:20.960: SkinnyAddDnToHwConference: Adhoc new conference se
tup failed!
1681762: Jun 25 20:02:20.960: ephone-3[11][SEP001E7AC364C7]:DisplayMessageTag: t
ag 138 (Unknown Tag)
1681763: Jun 25 20:02:20.960: ephone-3[11]:Failed to add DN 34 chan 1 to confere
nce with conf_dn 34 chan 2
1681764: Jun 25 20:02:26.720: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now c
onnected to 8984344 N/A
1681765: Jun 25 20:02:28.008: ephone-3[11][SEP001E7AC364C7]:SoftKeyEventMessage
event 27 line 1 callref 14467
1681766: Jun 25 20:02:28.008: ephone-3[11]:Block FAC when Sk pressed.
1681767: Jun 25 20:02:28.008: ephone-3[11][SEP001E7AC364C7]:SK ConfList line 1 r
ef 14467
1681768: Jun 25 20:02:28.008: ephone-3[11]:ConfListButtonPress
1681769: Jun 25 20:02:28.008: ephone-3[11][SEP001E7AC364C7]:SkinnyConfListButton
Press on line = 1, chan = 2
1681770: Jun 25 20:02:28.008: SkinnyConfListButtonPress: streamID is NULL, dn no
t in conference!
1681771: Jun 25 20:02:34.528: ephone-3[11][SEP001E7AC364C7]:SoftKeyEventMessage
event 15 line 1 callref 14467
1681772: Jun 25 20:02:34.528: ephone-3[11]:Block FAC when Sk pressed.
1681773: Jun 25 20:02:34.528: ephone-3[11][SEP001E7AC364C7]:SK Join line 1 ref 1
4467
1681774: Jun 25 20:02:34.528: ephone-3[11]:JoinButtonPress
1681775: Jun 25 20:02:34.528: SkinnyJoinButtonPress: party=0 master_conf=0 parti
cipant_conf=0
1681776: Jun 25 20:02:34.528: SkinnyJoinButtonPress: No selected party to join i
n conference!
1681777: Jun 25 20:02:34.528: ephone-3[11][SEP001E7AC364C7]:DisplayMessageTag: t
1681778: Jun 25 20:02:34.668: ephone-3[11][SEP001E7AC364C7]:CallPrompt line 0 re
f 0: USHE
How do I troubleshoot this issue?
natan.kasav Wed, 07/02/2008 - 23:13
its seemes that you are using all your dsp resources ...
can you post please :
show dspfarm profile
correct me if i worng you are try to using the meetme conference ?
