Network Newbie - Configuration Assistance.
Mar 26th, 2008
I have a Catalyst 2924, with a 2914 expansion module (4-port).
How do I configure these 4-ports to obtain DHCP addresses from a '2wire 2701HGV-W' 4-port router?
Thank you in advance.
Craig.
i-kendall Thu, 03/27/2008 - 15:46
Craig, you don't need to do any config on the switch for this. I presume the router is already configured to be a dhcp server, and providing all the ports and the router are in the same vlan, it should all work from power on.
