CSS:advanced-balance ssl - is url "/*" necessary?
Mar 26th, 2008
In some cisco.com configuration example I see url "/*" being called out as one element required to configure advanced-balance ssl (sticky ssl). But other resources do not have the url "/*". I have an example of each below. Is url "/*" just a default "any" that is really in the content rules by default? Or is the url "/*" really required to get the advanced-balanced ssl to function correctly. Any insight appreciated.
Example showing the url "/*" as needed:
http://www.cisco.com/warp/public/117/css_sticky_timeout.html
Example where url "/*" is not with the advanced-balance ssl:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/ssl/guide/examples.html#wp1000076
content ssl-rule
vip address 192.168.5.5
protocol tcp
port 443
add service ssl_module1
add service ssl_module2
application ssl
active
Diego Vargas Thu, 03/27/2008 - 08:57
The command "url" is not needed on this configuration, there is indeed a mistake on the first example.
With this kind of content rule what you are doing is just load balancing SSL traffic, so the CSS is not able to look at layer 5 (since it is encrypted), therefore there is no way to parse the URL.
Second example is correct:
content ssl-rule
protocol tcp
port 443
application ssl
active
Hope it heps!!
Diego M
