why ACS cannot display downloadable acl page
Answered Question
Mar 26th, 2008
I have a ACS for windows, version is 4.0.1.27.
after successfully installation, I found there is not downloadable acl item in the shared profile component? I can see its help on the right place.
Why didn't I configure downloadable acl in this ACS, is there any other works I need to do?
Thx
Correct Answer by Jon Marshall about 9 years 1 month ago
Try this.
Interface Configuration -> Advanced Options
Click checkbox for
User-Level Downloadable ACLs
Group-Level Downloadable ACLs
Click Submit
Then go back to Shared Profile Components and it should now be an option.
Jon
Overall Rating: 4 (1 ratings)
Correct Answer
Jon Marshall Thu, 03/27/2008 - 01:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try this.
Click checkbox for
Click Submit
Jon
