Integrate LMS 3.0.1 with Cisco Secure ACS 4.0.1
PJWHITBY
I am trying to integrate LMS 3.0.1 with Cisco Secure ACS 4.0.1
Configuration done at ACS end:
1. ACS is integrated with the domain.
2. NDG group "CiscoWorks" has been created.
3. The LMS server has been added as a AAA client with the pre-shared secret key in the NDG in step 2
Configuration done at LMS end:
1. LMS server has been switched to ACS mode.
2. ACS server IP address, ACS administrator username/password has been added and the pre-shared secret has been matched.
After doing all this and when I apply those settings I get
" Primary ACS Verification Status ( 10.x.x.x )
Tacacs+ Connectivity Reachable
HTTP/HTTPS Connectivity Reachable
AAA Client Not Configured
Secret Key Verification Not Applicable
System Identity User Not Applicable
Note : Verification failed for all ACS server(s). Please check your
settings. "
I have tried everything, deleting, recreating, bug list, forum posts, etc, etc.
Can anybody help me please correct this error
Joe Clarke
Make sure you have opened all TCP ports on the ACS for administration (i.e. ports 1024 to 65535). This is only needed for initial integration. Afterward, it is safe to reduce this to no less than 10 open ports. Also, if this is an ACS appliance, make sure the ACS administrator user configured in LMS is NOT the appliance administrator. The ACS administrator must be another user which has all ACS privileges.
Joe Clarke
you are a star, it works, much appreciated
