IP Communicator
Mar 26th, 2008
I am connecting to CCM4.1 thru VPN & have IPcommunicator installed on my machine.In IPC,under the preference option for TFTP server i have given CCM IP,i have done the phone config in CCM,but its still showing the error as "Phone not registered".
I checked the connectivity to CCM thru my machine, ping response is fine.
Can any one let me know what could be the possible reason for this error.
Overall Rating: 3 (1 ratings)
Adam Thompson Thu, 03/27/2008 - 08:08
I am assuming that the CCM IP that you configured is running the TFTP service.
Is there a firewall between the CCM server and the general network? If so, TFTP/voice traffic from your VPN network may not be allowed through the firewall.
If you are connected normally at work (not through VPN) does your communicator register?
navingolani Fri, 03/28/2008 - 00:03
Hi Adam,
Yes we do have a firewall in between CCM server & local network.I have asked the local team to open the TCP port 2000.Will let you know once done.
jbarcena Thu, 03/27/2008 - 11:25
On the IPC Preferences are you choosing the PC adaptor or the VPN? Try using the VPN, I also recommend you to take a sniffer trace to see the packet exchange
navingolani Thu, 03/27/2008 - 23:59
hi jbarcena,
I have used VPN Adaptor for under the IPC Preferences.
