Routing on calling ID
Mar 27th, 2008
  • Bronze, 100 points or more
I have a customer that would like to beable to route calls on caller IDs. If one of there VIP customers phones up they want the call directed straight to an Account manager. If any one else calls to a normal agent. Is it possible to do this and can it be done in ipcc express 4/5 and what lic would i need.
Matt
matthewpage Fri, 03/28/2008 - 12:08
Any one have a sample script or any thing for this that will route a calling number ??
michaelzhq Wed, 06/11/2008 - 12:46
Hi Matthew,
Did you find a solution? I have a similar requirement. Thanks.
Michael
matthewpage Wed, 06/11/2008 - 12:56
Hi Michael,
Sorry i havent been able to find a solution. Hoepfully some one sees this and can shed some light on the issue.
Matt
Jonathan Schulenberg Thu, 06/12/2008 - 03:56
  • Cisco Designated VIP,
    2017 IP Telephony
You can do this with the Get Call Contact Info step to save the calling number into a variable. Once you have that, you can evaluate it against a match statement, an XML document, or if you have premium, against a database such as your CRM system.
In the most simplistic example, you could use a match statement. Each branch of the statement would be a different calling number. Within that branch you could change the caller priority, the queue they will be placed in, or assuming that the account managers are not in UCCX, you could transfer the call to their directory number using the Call Redirect step.
If you will be changing this often I recommend investigating the external XML document or SQL database instead. This will minimize the changes to the script. Fewer changes equals fewer chances of screwing it up. :)
