dte signal on serial interface
rabeder
hi,
i have (perhaps) a silly question:
we have a enddevice which connects over a serial cable to a routers serial interface (enc x25).
the problem is, that the cable between has no pin 20 (dtr) and so the connection does not work because the router needs the dtr.
is there any possibility, that i "switch on" the dtr in the ios software?
i mean - perhaps - a interface command, which turns on dtr or that the router ignores dtr?
thanks for any answer
7 Replies 7
paolo bevilacqua
The command is exactly that, ignore dtr. Note you need a dce cable for what you want to do, (show controllers serial to know which cable you've currently).
hi,
thanks for answer - this would be exactly that, what i want and need - BUT:
r-altmuen1#sh controllers Serial0/0/0
Interface Serial0/0/0
Hardware is GT96K
DCE V.11 (X.21), clock rate 64000
idb at 0x456ECCF8, driver data structure at 0x456F4414
wic_info 0x456F4A18
interface Serial0/0/0
description r-altmuen1: to x.25 Datus (S0/0/0)
bandwidth 64
no ip address
encapsulation x25 dce
load-interval 30
x25 htc 20
x25 win 7
x25 wout 7
clock rate 64000
r-altmuen1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
r-altmuen1(config)#interface Serial0/0/0
r-altmuen1(config-if)#ign
r-altmuen1(config-if)#ignore ?
dcd ignore dcd
r-altmuen1(config-if)#ignore dcd ?
dsr ignore dcd dsr
r-altmuen1(config-if)#ignore dcd dsr ?
This command is not supported on this interface
Cisco 2821 (revision 53.51) with 237568K/24576K bytes of memory.
Processor board ID FTX1207A3A1
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
System image file is "flash:c2800nm-advipservicesk9-mz.124-18.BIN"
you are getting v24 and your x21(v11) pins mixed up.
pin 20 is for v24
pin 3 and 10 are control or as Cisco improperly says DTR for x21/v11
http://www.connectworld.net/x21.html
guves you the pin uses.
Sorry we mixed up the routers.
The correct interface is:
Interface Serial0/1
Hardware is PowerQUICC MPC860
DCE V.24 (RS-232), clock rate 19200
idb at 0x82A6E298, driver data structure at 0x82A7602C
SCC Registers:
Do you have any further ideas?
hi folks,
i've tried it with a V.24 DCE Cable on a WIC-2T and on a WIC-1T. With both configurations i'm not able to enter the "ignore dtr" command. The only reference i've found is that the "ignore dtr" command is supported on a NM-16A/S module. (http://www.cisco.com/en/US/docs/ios/12_4/interface/configuration/guide/hnm16as.html)
Does anybody know if there is a solution to enter the command on a WIC-2T?
I am unsure why you are trying ignore DTR on the router, the router is supplying DTR , likewise the other device needs to supply DTR or it needs to be strapped to another pin and marked high, do a search on the v24 handshake to understand it more.
When you use a DCE cable to the cable suplies DCE hugh to the router,
do a show interface of the router with the dcs cable.
the thing is, that i have a self-made cable between the routers v24 dce-cable and the cashing machine.
in this self made cable i have no pin 20 which is wired.
i have this szenario over 300 times, and it would be very comfortable if i could disable that the router waits for dtr from the enddevice.
of course we could open the 300 self made cables and strap to another pin - but that is a lot of work -
With DTR Pin (20) connected:
Router#sh int ser 0/0
Serial0/0 is up, line protocol is up
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 9 Kbit, DLY 20000 usec,
Encapsulation X25, loopback not set
X.25 DCE, version 1984, address ,
RESTARTs 2/0 CALLs 0+0/0+0/0+0 DIAGs 0/0
LAPB DCE, state CONNECT, modulo 8, k 7, N1 12056, N2 20
T1 3000, T2 0, interface outage (partial T3) 0, T4 0
VS 1, VR 1, tx NR 1, Remote VR 1, IFRAMEs 3/4 RNRs 0/0 REJs 0/0 SABM/Es 0/2 FRMRs 0/0 DISCs 0/0
Last input never, output 00:00:13, output hang never
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
9 packets input, 51 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 buffers swapped out
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Router#sh controller
Interface Serial0/0
idb at 0x824450CC, driver data structure at 0x8244C7F0
SCC Registers:
Without DTR Pin (20) connected:
Serial0/0 is down, line protocol is down
X.25 DCE, version 1984, address , state R/Inactive, modulo 8, timer 0
Defaults: idle VC timeout 0
cisco encapsulation
input/output window sizes 2/2, packet sizes 128/128
Timers: T10 60, T11 180, T12 60, T13 60
Channels: Incoming-only 1-1, Two-way 2-2, Outgoing-only none
LAPB DCE, state DISCONNECT, modulo 8, k 7, N1 12056, N2 20
VS 0, VR 0, tx NR 0, Remote VR 0, Retransmissions 0
Queues: U/S frames 0, I frames 0, unack. 0, reTx 0
Last input never, output 00:09:23, output hang never
Last clearing of "show interface" counters 00:11:07
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
9 packets output, 33 bytes, 0 underruns
0 output errors, 0 collisions, 11 interface resets
0 unknown protocol drops
3 carrier transitions
DCD=up DSR=up DTR=down RTS=up CTS=up
Interface Serial0/0
