Tomcat, ICServe and CSRegistryServer Failed to Run
Mar 27th, 2008
I need help on Ciscoworks 2.5, web interface shows that the CW is still initializing. But found that the Tomcat, ICServer and CSRegistryServer failed to run. I already tried manually starting the processes but nothing happens.
Below are logs from stdout.log
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0xA73C25B8
I've attached the output of pdshow and stdout.log
Joe Clarke Thu, 03/27/2008 - 10:02
Your NMSROOT/MDC/etc/regdaemon.xml is corruppt (probably a zero byte file). This was a bug in LMS 2.5. If you do not have a good backup, you will need to reinstall all of LMS from scratch. Then you should immediately upgrade to LMS 2.6 which is freely downloadable from (start from , go to LMS 2.5.1 then to 2.6).
che.candeloza Thu, 03/27/2008 - 23:42
hi jclarke,
i have another LMS of the same version that is working, can i just copy the NMSROOT/MDC/etc/regdaemon.xml to the problematic server?
Joe Clarke Fri, 03/28/2008 - 09:25
No. This file is tied closely to the individual server. You would need a good backup from the server with the corrupt file.
